跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
381 个问题 查看全部
Why do I have a "burn" mark on my screen?
I was removing the back glass panel of my iPhone Xs Max using a heat gun to loosen the adhesive. I must have either used too high of a setting or heated too long. The front panel now shows a “gold" patch in the upper right corner. You can still see all the pixels in that area through the patch. I've attached photos to show. Would I have to replace the whole panel or could I clean this somehow?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Lol u have a burn mark on ur screen because u burnt it, lol
Leave it alone for a little while and see if it fades if it doesn't or it gets worse then u would need to replace the screen.
完成的
添加一条评论
2个答案
最有帮助的答案
@thejunhorde to much heat from the heat gun is the cause for this. You need to replace the display to fix this. 更换iPhone XS Max屏幕总成
这个答案有帮助吗?
得分 1
添加一条评论
I have the exact same issue, happened in the exact same manner. Unfortunately the answer to this problem as far as people have told me is to replace the screen. Since in my case under the patch I can see clearly that colors are displayed well. And by this I mean the Green battery logo is still green I am thinking maybe we have burned the top glue and that is what is causing the weird colors. I am thinking about trying a top glass replacement ( not me obviously because I don’t have the right tools ) and see after as I don’t want to replace the screen because I will loose true tone and also refurbished original OLED is quite expensive. Please post here your resolution because I am interested in this topic
这个答案有帮助吗?
得分 0
1条评论:
You won't loose true tone if done properly
完成的
添加一条评论
添加你的答案
Tony Salonia 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 43
总计 3,193
