跳转到主内容
加入维修社区 - 创建账户
ATX 中塔式机箱与其他中型计算机机箱具有相同的通用构造和部件。
BIOS Stalls after loading date line
AMI BIOS stalls at the date line on a MSI motherboard. What’s the issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Tom Zonsius
What model is the MSI mainboard?
If on POST Screen you can press on the Tab key to see more info.
Normally stalled / error hard disk, faulty drives connecting to the sata ports, etc can stall the detection.
I would suggest you to remove the sata drives one by one to eliminate or find the issues.
if all has been removed, but there is no improvement, consider clearing your cmos and see if it help.
one note you have to consider before clearing cmos is if you have bitlocker enabled.
clear will ask for recovery key.
go ahead if you have backup recovery key.
lastly is to update the bios
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tom Zonsius 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 315
