跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Battery won't charge so I can only run on A/C power
these are my computer specs:
Model A1181 / 2 GHz Core 2 Duo processor
(C2D, Late 2006) MacBook 13"
The computer works fine while connected, but even though the battery is fully charged it will not take power from the battery. It won't even recognize it's there. I get a black X. I've used a different working battery and it didn't work neither. No liquid-spills have happened in this unit.
I've been reading around other people with similar problems and someone recommended a new magsafe-DC-In. but, if the computer gets power from the power cable plugged in, doesn't that mean that my MagSafe DC-In Board is working? also, I also read that it could possibly be the battery connector/sleep sensor, but that is usually the case after a liquid-spill, which hasn't happened.
help please!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'd look to the battery connector. Check your connection to the logic board first, here's how to replace it: MacBook Core 2 Duo Battery Connector Replacement
There's a non-energy star: MacBook Battery Connector/Sleep Sensor (non-Energy Star)
and an energy star according to which machine you have: MacBook Battery Connector/Sleep Sensor (Energy Star)
Provides battery contacts and sleep sensor for logic boards without Energy Star printed at the second RAM slot.图片
产品
$7.99
Provides battery contacts and sleep sensor for logic boards with Energy Star printed at the second RAM slot. May or may not have a liquid damage indicator patch.图片
产品
$17.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Citronex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 2,028
