跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1200 个问题 查看全部
Why is my iPhone X showing the charging symbol but gets stuck at 2%
Hi there, yesterday my iPhone X started acting out when I plugged it into charge. My phone was on 1% so I went to charge it and it worked fine, until I left it and came back to it having only got up to 2%. I have tried restarting it and cleaning out the port (however not professionally). So I left it on charge while I was asleep and woke up this morning to it being on 2%. I unplugged it and it went to 3% and then decreased normally until it got to 1%. I am using it now not plugged in and have been for about 15 minutes, is there any way it has charged but the number hasn’t gone up? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes, that may happen at times, power gauge doesn’t work properly because of a battery failure or a board failure. If you have used non original/certified cables or charged it with a car adapter chances of a board failure increase quite a bit. If you have a Mac or a PC available you can check battery condition with Coconut battery or 3Utools, both apps are quite accurate and can tell us more about battery status.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rachel Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 661
