跳转到主内容
加入维修社区 - 创建账户
Razer 于 2014 年 9 月发布的一款黑色人体工学游戏鼠标。它是 DeathAdder 系列中最受欢迎的一款。型号为 RZ01-0121。
How can I replace button switches?
My switch on the right click button got broken. I can’t find a replacement on any site. How can I buy one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Omron - D2F-01F (Japan), D2FC-F-K(50M)-RZ, D2FC-F-7M (20M), D2FC-F-K (50M)
I just replaced my switches with Omron - D2F-01F (Japan).
Those switch models are global numbers and easily searchable.
Kailh GM Red
Huano Micro Switches
TTC Gold.
Each of these manufactures also makes switches that work as substitutes but have a different tactile feel and actuation pressures.
这个答案有帮助吗?
得分 2
4条评论:
Any ideas what model is the middle switch?
由完成的
Yeah any idea what the middle mouse switch is? it seems to be 1 mm shorter than the stock standard middle mouse switch.
由完成的
I know this thread is old but I have a Deathadder Chroma and I successfully replaced the middle mouse switch with E-Switch part number TL1150AF070Q. I'm sure any switch of similar dimensions would get the job done, just make sure the actuation force is practical for your fingers. https://www.mouser.com/ProductDetail/E-S...
由完成的
About D2F-01F - it is ok, but not for too long. I replace mine with this maybe 1,5 a year ago and now it makes double clicks again, maybe 2 times for 50 clicks, but still annoying at work. Glad I bough some DeathAdder just in case and another switch, so I will use DeathAdder in the meantime when I find some time to solder the new switch :)
由完成的
添加一条评论
You can use an old mouse switch it’s the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emirhan Ulken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 43
总计 4,524
