跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Ps3 won't turn on. Beeps 3 times. No red/yellow light flashing.
So, I tried to turn my ps3 on this morning and I noticed that it would not power up. I decided to unplug it but still had the same problem. I flipped the switch in the back to the off position and then back to the on position. Thats when I noticed that the "RED" light that indicates power to the unit was not on. I have tried to to turn the ps3 on numerous times with no success. The only thing that happens is the console beeps 3 times and then it shuts down. There are no RED or YELLOW flashing light... It just beeps 3 times and then it shuts down. Does anyone know what the problem might be? Or if there is a quick fix. Your input would be greatly APPRECIATED!!!
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Sounds like it's either the power supply or the motherboard. Unfortunately, diagnosing exactly what part of the motherboard is bad is a very difficult task, and if a new power supply doesn't fix it, you would probably be looking at an entire new motherboard.
PlayStation 3 Power Supply图片
指南
PlayStation 3 Power Supply Replacement
难度:
中等
20 - 25 minutes
PlayStation 3 主板图片
指南
PS3主板更换
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
I just had this problem turned out it was the small mother board in the controll switch (on/off , eject disc )
这个答案有帮助吗?
得分 0
添加一条评论
I had the same exact problem but the problem was just the HDMI plug wasn't plugged all the way in. Heyyy, problem fixed!! U can call me Ayhaunna the Fixer!! (Bob the Builder) u get it?? No?!, ok!...have u a good day u guys
这个答案有帮助吗?
得分 0
添加一条评论
Just had a fat PS3 come in to X MARX THE BOX for this. No flashing lights but instant 3 beeps and light stays red. Pulled it apart for the customer and what they thought was a overheating issue was much worse. Liquid damage(soda) and it bridged 6 of the SATA pins, possibly from heat, on the board. Heat and liquid are the main killers and this is the second fat PS3 I've had in this year with liquid damage. The first had corrosion eating the connections so I cleaned it all up and got it running but it failed again but much worse within a few months. That one had at least 20 circuits damaged but this one may be able to be microsoldered to fix the issue. Always put your PCs and consoles in elevated and well ventilated areas and NEVER set drinks or liquids within a arms reach of them. Lost my Atari 2600 in 1985 because I used to set my milk on it but the Atari wasn't thirsty. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sleepy Will 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 22,718
