跳转到主内容
The M331 Silent Plus is a wireless mouse released by Logitech in November 2016. The mouse connects via a USB receiver and is powered with a single AA battery.
My USB only works when under pressure
Ok, so I couldn’t find my mouse (M310) in the options thing. Anyways it is wireless and when I plug the USB thing into the computer it doesn’t work. It only works when I apply pressure, which isn’t practical. Anybody have a solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It sounds like a physical connection issue either in the USB nano-receiver or at the port. It could be that the nano-receiver’s connectors are loose or dirty, and applying pressure makes it sufficiently contact the computer USB’s port pins. Try cleaning the receiver’s connectors as well as trying a different USB port. You can also try to use pliers to slightly squeeze the top & bottom of the receiver so that it fits into a USB port tighter.
It may also be possible (though less likely) that a solder joint in the receiver has broken—applying pressure bridges the broken contact. That would require some careful board inspection and soldering.
You can also buy a new receiver for your mouse. Just make sure it’s compatible with your mouse model.
这个答案有帮助吗?
得分 4
添加一条评论
are the batteries good in the mouse?
have you try another USB port or use it in another computer?
is very rare that dust or hairs get under the buttons in a wireless mouse but if you could open it you can check.
There is a little button under the plastic when you press the right or left buttons. So applying pressure indicates that the button under is being press but there is something underneath preventing the signal to the mouse to respond.
The mouse could also beginning to go bad.
这个答案有帮助吗?
得分 1
5条评论:
the usb that plugs into the computer only connects to the mouse when i push down on the usb. the batterys are good and the mouse isnt broken i think its just the usb
完成的
same situation here. I think a is a fault in the design of the usb reciever.
完成的
My logitech unifying receiver has the same problem after my laptop fell on the ground with the receiver equipped
完成的
I am now on my second Logitech wireless mouse in which the USB dongle only works with side pressure regardless of the USB port it is plugged into.
完成的
Hackintosh is a customized PC built to run macOS, offering the power and flexibility of standard hardware with the sleek experience of Apple’s operating system. Ideal for tech enthusiasts, Hackintosh systems combine performance, affordability, and macOS compatibility. From laptops to desktops, these setups allow creative professionals and developers to use macOS without purchasing a Mac—though they require technical knowledge and careful configuration. https://hackintosh.expert/
完成的
添加一条评论
添加你的答案
TheTinCanMan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 118
总计 9,255
