跳转到主内容
加入维修社区 - 创建账户
Sony TCM-919 是一款便携且轻便的盒式磁带播放器,具备音频录制功能。这款 20 世纪 90 年代的设备配有 3 位数磁带计数器、麦克风、自动停机功能以及前置扬声器系统。
Cassette player does not turn
The unit is actually a tcm 450 but the particular model was not present on the selection list. I found it in my grandma’s drawer along with a bunch of tapes, and I’m pretty sure it worked a year ago or so. when I shoved a tape in with aaa batteries, nothing happened. I removed the tape to see if the knob thing inside was turning, and it didn’t. Ibplayed with the volume knob and all the buttons, but it was failing to work. I can feel that the cassette player is trying to make it rotate— I can feel it when I touch it with my finger while pressing the ‘play’ button, but yet, nothing is happening. Plz Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi @pxlbluejay ,
Here’s a link to the service manual for the cassette player.
It has full schematics of the player which should help you find out where the problem lies. If a component is faulty it also has the parts list.
Hopefully this is a start to get the player going again
这个答案有帮助吗?
得分 2
1条评论:
jayeff,
thanks a lot!
由完成的
添加一条评论
Probably a bad drive belt. If you can open it up and take a look chances are that the old rubber belt has gone soft and stretchy, without the right tension the motor wont be able to drive the pulleys. You might hear a mild screeching noise when you hit play, most likely the belt skipping. You can buy replacement belts on ebay or maybe amazon.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay Kwon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,447
