跳转到主内容
加入维修社区 - 创建账户
Sony Cyber-shot DSC-W830 是一款 2010 万像素的相机,旨在拍摄静态图像并支持最高 720p 分辨率的视频录制。
SD card write protected
my SD card is write protected so I can’t take pictures. It happens with every SD card I use. The physical write protection is turned off, I can’t reformat the card because I just get a pop up that says the SD card is write-protected.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Can you format the SD Card in a computer and then try it in the camera?
If it still fails, it appears as though the contact in the SD Card reader in the camera, that detects the position of the lock switch on the SD Card may be bent or stuck, indicating the card is locked when it isn't.
You’ll probably have to open the camera to access the SD card reader and most probably have to replace it.
Here’s a link to the ifixit Sony Cybershot DSC-W830 主板更换 guide which may be of some help in gaining access to the card reader.
If this seems too daunting, contact a reputable, professional camera repair service and ask for a quote
这个答案有帮助吗?
得分 2
1条评论:
I put the card in the computer, but it still failed in the camera. So I will follow up on this solution. Thanks!
由完成的
添加一条评论
添加你的答案
tagarrison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 26
总计 751
