跳转到主内容
加入维修社区 - 创建账户
巴诺书店(Barnes & Noble)于 2011 年 11 月发布的 7 英寸多媒体平板电脑。维修简单,只需使用简单的撬具和螺丝刀即可完成。
How to fix battery plug
Battery plug broken wireplacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Please describe what’s broken first,in better detail. . Is it the plug on the battery or the plug on the logic board that the battery plugs into? All it is,is an electrical connection. Yes of course it “can” be fixed. But that would likely require microsoldering to successfully fix it. If you post a picture that would help us visually. But if you want help you need to make it easy for us to give you advice on the exact problem.
On the logic board,the connector is generally soldered. It is plastic too. This requires skill and tools to replace. If it’s the battery plug(directly on the battery wires),you can just get a new battery(HIGHLY RECOMMENDED).
let me know if you have more questions
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bernard Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 31
总计 330
