跳转到主内容
加入维修社区 - 创建账户
Moto E 系列智能手机的第五代产品,于 2018 年 7 月发布。型号为 XT1921
My left side isn't working
ok so I dropped my phone in water not that much but it did get wet, so I dried it off and restarted it and I had to put in my code to fully unlock it and my code starts with a 6 and it’s a number code so every thing types in but not the left side so 3,6,9 or the enter button!!!!! what do I do????????????????????????????????????????????????????????????????
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible to prevent any further damage.
After this you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most electronic parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain scents and is not as effective. If you do use it, check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kayla Lyles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 268
