跳转到主内容
Televisions made by the Chinese multinational electronics company, TCL.
263 个问题 查看全部
How to Flip or Invert the image on a TCL 50"
i am trying to make a video wall with 6 TV TLC , but i Need to flip or invert the image on some of them so i could put it on their own spot. The six tv’s going to show up the same image but still i would like to flip another tv so it could be on vertical mode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@samuelmgm12
you did not tell us what model this TCL is. Things like that are only possible if the soft/firmware supports that in it’s system. The only other way is by modifying the T-con board but there is only limited information for TCL branded TV’s. I suggest you check through the menu of this model and see if you can find what you are looking for.
这个答案有帮助吗?
得分 2
1条评论:
Oh ok, Thats why i havn't bought it yet, because I need to be very sure to recommend the church to buy the units after check if the flip or invert image are supported by the brand
完成的
添加一条评论
062598 menu 001 to 999
Dial this code
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samuel Mauricio Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 54
总计 3,876
