跳转到主内容
Unglue MacBook Air battery cells?
I have a MacBook Air 11-inch from 2011. A few years ago the battery started swelling and I bought a cheap used replacement on eBay.
The replacement isn’t so great since the battery life is poor and the plastic screw holes are damaged. It fits in fine for now but I’d prefer something better since the computer is now getting more use than before.
I still have the old battery and it’s clear that only half (3) of the (6) cells are swollen/bulging. The others (3) appear normal. Is there a safe way to detach the swollen cells? Can the MacBook Air run with only half the cells? Can I transplant cells between battery enclosures? I don’t want to attempt this if there’s a legitimate fire risk.
Any thoughts appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sorry your system will not work on half the cells. You are more likely to hurt your self given the batteries condition.
Dispose of the battery properly! Don’t mess with it!
这个答案有帮助吗?
得分 4
添加一条评论
As Nike says, “Just do it”
MacBook Air 11" 2011 中期 电池更换
MacBook Air 11" (Mid 2011-Early 2015) Battery
MacBook Air 11" (Mid 2011-Early 2015) Battery图片
产品
$59.99
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 150
