跳转到主内容
MLB 820-00850 does NOT match boardview/schematic... any ideas?
i took in a 2018 mbp13 A1989 after a liquid damage and a serious moron opened it up.
several pieces are missing from the MLB, but one cannot be identified as it exists on the board (and the teardown photos) but NOT in the boardview or schematics. has anybody worked on this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@reverendalc preliminarily it appears to be a 74AUP1T97GM IC Gate. Check the datasheetLow-power configurable gate with voltage-level translator and you may confirm by measureing on the solder pads. Check with Digikey.com or Mouser and see if they have the right package. The part itself is less than $1.00USD
这个答案有帮助吗?
得分 3
1条评论:
Awesome thanks I’ll look into that ASAP
完成的
添加一条评论
You'll need to locate a more upto date schematic and board view. The one you have is clearly incomplete. The newer models have been harder to get and I've only found early drafts which are incomplete.
这个答案有帮助吗?
得分 0
1条评论:
Yes it’s clear that this boardview is incomplete. I was hoping somebody may have this board to look at for me...
完成的
添加一条评论
添加你的答案
Ronnoc Nailli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 2,056
