跳转到主内容
The Iconia One 10 was released in October 2016 by Acer. With a 10-inch screen, it has dual-band wifi, 24GB of storage, and a long battery life. Model number: B3-A30
Is the screen digitizer attached to the LCD?
Wondering if I can just buy the LCD alone, or have to get the LCD+digitizer assembly, as the touch still works fine, just the LCD is cracked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
tipoo the digitizer and the LCD are separate pieces. You can replace one without having to replace the other
Acer Iconia One 10 B3-A30 Repair Screen Replacement
这个答案有帮助吗?
得分 2
添加一条评论
Yes, I do believe this tablets digitizer is attached to the LCD. It would be recommended to replace them both rather then try to do an at home adhesion if that is the case. I attached a screen repair link below and it does show two pieces at the end. however I cannot tell if the white frame is a digitizer or just a cover.
Might want to drop that author a message.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tipoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 212
