跳转到主内容
加入维修社区 - 创建账户
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
Why is my mower not wanting to engage the blades right?
2013 cub cadet 1050. When I engage the mower deck it wants to sputter to a stop. If I mess with the throttle a little it will come on and mow perfectly. Sometimes it just does its little sputtering fit and will engage. New belt, spindles, blades, and fuel filter.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@stevenstickley make sure that you replace/clean the air filter and the spark plugs. A plugged air filter or faulty plugs can cause the engine to run rich. after you check on that I would recommend checking the choke/carburetor. If the mower still bogs down after that, the problems is most likely a carburetor. A good cleaning of the jets and float (needle valve) and setting the choke should work.
这个答案有帮助吗?
得分 1
2条评论:
It runs perfect when the decks off and after the mower finally engages, that's what threw me off a little
完成的
It sounds like it is choking when you put a load on the engine which is commonly caused by a carb that is running to rich.
完成的
添加一条评论
添加你的答案
Steven stickley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 220
