跳转到主内容
加入维修社区 - 创建账户
Bose Solo 5 电视音响系统的维修信息。发布于 2016 年。型号:732522-1110。
Device not powering up
I bought the above device online, but even after changing adaptors and power sockets, ai can't get the device to power up. The power suppluly is getting the power (got checked) and the device makes a brief sound, but nothing after that. Even bluetooth or power indicators do not come on. What could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Hi,
Did you ever get this question answered? Or did you have to fix it?
(I have the same problem also. )
由完成的
me too. it comes harder to get what s going on as the device has not any power button, nor any button at all
由完成的
bose solo 5 requires the remote the unit initially came with in order to turn on. although i just read that you can program a universal remote with the bose frequency codes to use a different remore. I programmed my harry potter RF wand to control it with gesture, flick forward for power , flick up for vol up etc.
由完成的
also, did you try using a multimeter to make sure that the board has clean connections?
由完成的
bose es como los iphones caros $.. para poca cosa que hacen habiendo equipos con precio justo que hacen lo mismo o mejor pero si quieren presumir que tienen dinero pues sigan apoyando MAc o Apple y Bose
由完成的
添加一条评论
1个答案
最有帮助的答案
There IS a problem with 20v to 5volt conversion. A circuit called 54335 to changé or solder a miniconverter card instead. Tutorials on youtube
这个答案有帮助吗?
得分 1
2条评论:
See: https://www.youtube.com/watch?v=F0d_mgV5...
It's in German, but has English subtitles with enough info to perform testing and fixing the 20vdc to 5vdc converter defect. If you want info on the defective chip: https://www.ti.com/lit/ds/symlink/tps543...
I will be ordering https://www.mpja.com/Micro-Adjustable-St... as a full PCB replacement for the defective chip.
由完成的
Hi, I have stable 5v output from 54335, but the device is not turning on (the led blinks for a few miliseconds). The IC amp is getting 20v for ~2sec and then it starts to go down to 0v. What can be the cause?
由完成的
添加一条评论
添加你的答案
Rajesh Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 57
总计 3,958
