跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
202 个问题 查看全部
Mac Pro 4.1 won't turn on - 5V STBY only diagnostic light
Hi,
Got a Mac Pro 4.1, no sign of life except the 5V STBY led in diagnostic.
Full led when pressing DIAG button.
No red lights when CPU tray removed, I considered the backplate board suspect number one.
Computer was used for a long time near the sea…humid.
Any feedback appreciated, are there any PSU testers for a MPro 4.1? :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@tbrep try these steps and let us know what you get:
1. Verify that connection between power supply and backplane board is undamaged and secure. Verify that power button and front panel board cable connections to the front panel board are undamaged and secure. See Functional Overview.
Yes
Go to step 2
No
Reseat all connectors and retest.
2. Connect AC power cord to the computer. Verify the 5V STBY LED illuminates when you press the DIAG button on the backplane board.
Yes
STBY LED illuminates, but computer won’t power ON.
Go to step 4.
No
Suspect power supply failure.
Replace power supply and go to step 3.
3. Verify the 5V STBY LED illuminates when you press the DIAG button on the backplane board.
Yes
Issue resolved.
No
Go to step 5.
4. Disconnect the front panel board. Momentarily jumper the pictured SYS_PWR solder pads on the backplane board. Verify the computer turns ON.
Yes
Front panel board or power button faiure. For front panel board, use code M01. To verify power button, go to Power Button Stuck.
No
Go to step 5.
5. Reduce computer to minimal configuration. Verify the 5V STBY LED illuminates when you press the DIAG button on the backplane board.
Yes
Suspect a module that has been removed. Reinstall modules until symptom reappears. Replace affected module. Then go to step 6.
No
Replace backplane board and retest.
6. Reconnect the processor board without processors. Press power button and verify computer turns ON. Note that you can identify the computer has started up by fans and LEDs; however, there won’t be any other activity since there are no processors.
Yes
Add processor A and retest.
If computer power remains stable, the power issue is resolved.
No
Go to step 1.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
TB_rep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 68
总计 5,237
