跳转到主内容
加入维修社区 - 创建账户
1999 年发布,初代 PowerMac G3 的继任机型,主频 300-450 MHz,配备 64 或 128 MB 内存,6 或 12 GB 硬盘
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
edith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,496
