跳转到主内容
Any small, single-cylinder carbureted gasoline engine, usually used for lawnmowers. The engine used to create these guides is a Briggs and Stratton 300e series engine.
20 个问题 查看全部
My Craftsman ys 4500 20 hp cranks but wont start even with start fluid
I accidentally ran over a chunk of wood and the mower shut down so I figured I sheared the flywheel key and replaced it and the spark plug with no luck I also sprayed starting fluid into the air filter after taking the filter out and nothing happened it just cranks over very fast but won’t start PLEASE HELP !!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Lou C This “I also sprayed starting fluid into the air filter” points to your mower not having a spark. Check on that first. If so, you do want to let us know what the exact make and model number for your mowers engine is.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lou C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 21
总计 204
