跳转到主内容
加入维修社区 - 创建账户
Lenovo G50-80 是联想于 2009 年发布的一款入门级个人笔记本电脑。该笔记本配备 15.6 英寸屏幕,并使用 Intel GPU 处理器。
OneKey Recovery/ HDD upgrade to SSD
Hi, I had this laptop for almost 3 years now and I have been looking for an upgrade I got a 480gb SSD I copied all my data from the old HDD to the SSD using a software but once I replaced them and tried to boot the OneKey recovery would pop up and non of the opinion initial backup nor the user backup work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
What was the size of the original drive. I don’t recommend this software. You should have bought [关联产品丢失或禁用: IF107-131] and used this https://www.macrium.com/reflectfree . I never had issues with macrium.
这个答案有帮助吗?
得分 0
11条评论:
The original drive is a 1TB HDD, and I did use the macrium reflect 7 for copying the data I wanted to use the SSD as a boot drive and the HDD as external I already have hard drive enclosure with USB 3.0
完成的
The only problem I get is with the OneKey Recovery I searched online and couldn’t find a way of bypassing it or disabling it
完成的
I think not all your files fitted in. You should have bought bigger drive. How much free space did the original have?
完成的
About 600GB was free
完成的
After transferring all my files there was about 70GB free left on the SSD
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Nedzhati 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,609
