跳转到主内容
Repair guides and support for televisions manufactured by Sony.
752 个问题 查看全部
Sony bravia KDL 43W800D red light blinks 5 times
Sony bravia kdl43w800D red light blinks 5 times. Called sony service technician he checked and told they will take to service center . Full panel or child card may be faulty. Pls suggest and guide about further course of action
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Lalit Sahoo  the 5 blink error code can have quite a few different causes. Ranging from the T-con board to a bad panel and a few things in between. If you have the original TV remote than try to see if this will work on your set:
1. In standby mode, press the following buttons on the Sony remote:
DISPLAY....5....VOL(-)....TV POWER
2. On the left side are the blink codes. On the right hand side is the error count.
3. Under 005, you'll see three listings... TCON, HFR, and P-ID (panel).
4. Let us know what errors your set shows.
If that does not work on your set, then you will have to remove the back of your TV and check the boards. Try to rule out/in the T-con board as faulty. Disconnect the LVDS cable to the T-CON board, the cable between the Main board and the T-CON board, and see if the error code will change. Let us know what the result is.
这个答案有帮助吗?
得分 3
2条评论:
Unable to find display button
完成的
Where is the display button on my Remote?
完成的
添加一条评论
Hi, my sony tv has the same problem but managed to go into self diagnose mode please view the screen give your comments sir. The tv boots up showing sony logo then will go into protect mode. Blinks red 5 times.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lalit Sahoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,940
