跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
My iPhone 7 is boot looping after Housing Replacement
Because I am new to repairing small electronics, I was bound to make a mistake just replacing my iPhone 7’s bent housing. This problem did not exist before replacing the housing, so I am wondering what is causing my phone to boot loop until either the battery completely drains itself out, force shutting down the phone via holding only the power button, or disconnecting the battery.
My hypothesis that something went wrong to the logic board when connecting the flex cables for the screen, and that microsoldering may be the only way to fix the problem. This is because recovery mode worked when the phone was plugged to a PC, but the PC cannot communicate to the phone whatsoever, meaning the dock connector isn’t the problem. Though this is a assumption, I assume the problem is within the components in the logic board.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Bent housing might imply flexed board that may bring to a number of issues, including audio IC and baseband IC but doesn’t exclude a number of things. iPhone 7 are a pain in the … (insert your fav. part here) when it comes to bootlooping as they can get mad for a bad dock, a faulty front camera, a bad home button, plus board issues. You can try removing the logic board from the housing, plug in a known good dock, battery and a screen and plug in the lightning cable and see what happens with bare minimum. If bootloops persists, remove screen too and plug it into a PC to see if it boots. If bootloop stops plug back parts one by one until you find the culprit.
这个答案有帮助吗?
得分 4
3条评论:
Okay, I will try that, but right now the battery is absolutely drained so I might need to find a replacement battery before using this method.
What I do know is that the bend is not where the logic board is, so I assume it is safe. The dock connector IMO is the hardest large component to take out, since the dock connector needs precise alignment so that the flex cable can connect to the logic board nicely.
I will comment back to see if this method works.
完成的
Alright, it turns out the dock connector was misaligned, so the connector only inserted to half of the socket. The iPhone now runs like normal now. Thanks for the answer!
完成的
Glad I could help getting it sorted out :)
完成的
添加一条评论
I wouldn’t expect the board to get damaged during a housing swap. This sounds like a battery problem. Try a known good battery and let us know the results.
这个答案有帮助吗?
得分 1
添加一条评论
That is the loose connection of SWI line of battery to battery connector,Try good connection between battery connector & battery,If the same change the new battery and check.
这个答案有帮助吗?
得分 1
添加一条评论
Is power and volume flex button iphone 7 the same as iphone 8 or it has differences
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Allen petalver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 185
