跳转到主内容
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90 个问题 查看全部
I dropped mycharge 3 in the ocean yesterday
It worked completely fine without trouble when I got it out of the water but when I got home I turned it off and put it on the charger. Later on (this morning around 7:00) it would stay on, didn’t make any noise even when I used the Bluetooth button to connect it with my phone it wouldn’t work and it still doesn’t make noise even when it turns on. What do I do and or how do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@james1243 possibly a short circuit or otherwise damaged component from the water. For now, you do want to stay away from charging it or trying more often to turn it on. That could make a bad situation worse.At minimum go ahead and disassemble everything JBL Charge 3 主板更换 and visually check the motherboard as well as other connections etc. You do want to clean everything with +90% isopropyl alcohol and a soft brush. After you clean it replace the battery and the reassemble and reevaluate.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Correia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 115
