跳转到主内容
大量松下数码相机的维修指南。
348 个问题 查看全部
LCD screen scratched on Lumix DMC-FZ18
The screen on my DMC-FZ18 camera is scratched. I thought that it needed a new LCD, but after dismantling, I found that it is the “window” part of the rear case that has the scratch.
Questions:
  1. Are replacement parts available?
  2. Is there an easy way to test whether it is plastic or glass?
  3. Is Cerium Oxide paste safe to use to polish out the scratches?
More details including photographs here .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Thanks for that reply. I had already decided to risk using cerium oxide which worked quite well, and then used a plastic polish for a final finish. The result is as good as I could expect given the initial deep scratches.
I had already updated the description.
完成的
Well good for you. We do not read updates on questions from iFixit on external Blogs. Questions are being answered on here and should also find the solutions on here. Anything else could be considered spam, which I am certain is not your intend.
完成的
I don't really understand your objection. The blog entry was directly relevant and contained exactly the sort of detail expected on ifixit and contained links back to ifixit. The question was genuine, and my own repair was only attempted when I received no (quick) answer. I am still hoping for a reply explaining how to obtain a replacement rear case or screen.
I did consider contributing a partial teardown of the DMC-FZ18 to ifixit, but because I had to use an old limited camera, most of the photographs were pretty poor. The few decent pictures were on the blog, but that is not very complete. But still useful, I hope, to others with DMC-FZ18s.
完成的
添加一条评论
1个答案
最有帮助的答案
Querty  you can most certainly try and it should not make it worse. I use 1200 grit wet sandpaper to remove scratches on a acrylic aquarium and light cover. Afterward I use metal polish to buff it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Querty 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 122
