跳转到主内容
Can I only replace the lcd
My display is half black, I already check with an external monitor and works, but the cuestion is..Do I have to buy the whole display part or can I get only the LCD part and attach it? thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for your help!!! nice meeting you guys, now I know were to ask!! jejeje
apreciated
V>
完成的
添加一条评论
3个答案
已选择的解决方案
Here's the part you need: MacBook Pro 15" (Models A1226/A1260) LCD Panel
MacBook Pro 15" (Models A1226/A1260) LCD Panel图片
产品
$179.99
这个答案有帮助吗?
得分 9
2条评论:
Use this guide to open it and make sure you are ordering the correct part: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
完成的
The actual problem is most likely a failed CCFL tube, but those type repairs are best left to professionals.
完成的
添加一条评论
Vikotiz,
The confusion is because Apple does not sell the LCD itself, so if you talk to an Apple authorized repair shop they will tell you you NEED to replace the entire top half. But, like Mayer says, You can buy and replace just the LCD and save a ton of money.
这个答案有帮助吗?
得分 7
2条评论:
+ vote, Kyle, your expertise is most welcome here. Please list your web site in your profile. Also anything you have on half-screen issues would be welcomed along with sources for CCFLs for large screens. Thanks
完成的
I'm actually a frequent customer of eTechParts; fantastic customer service!
完成的
添加一条评论
I agree with both guys, however if you aren't a seasoned tech this repair is quite difficult and you are very likely to ruin the framing if not careful. Also, you can't LCD shop on this machine because there are only 2 lcd's that will work properly and they are now discontinued which is why they are so expensive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vikortiz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,314
