Can I only replace the lcd
My display is half black, I already check with an external monitor and works, but the cuestion is..Do I have to buy the whole display part or can I get only the LCD part and attach it? thanks for your help!
Here's the part you need: MacBook Pro 15" (Models A1226/A1260) LCD Panel
这个答案有帮助吗?
Use this guide to open it and make sure you are ordering the correct part: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
The actual problem is most likely a failed CCFL tube, but those type repairs are best left to professionals.
Vikotiz,
The confusion is because Apple does not sell the LCD itself, so if you talk to an Apple authorized repair shop they will tell you you NEED to replace the entire top half. But, like Mayer says, You can buy and replace just the LCD and save a ton of money.
这个答案有帮助吗?
+ vote, Kyle, your expertise is most welcome here. Please list your web site in your profile. Also anything you have on half-screen issues would be welcomed along with sources for CCFLs for large screens. Thanks
I'm actually a frequent customer of eTechParts; fantastic customer service!
I agree with both guys, however if you aren't a seasoned tech this repair is quite difficult and you are very likely to ruin the framing if not careful. Also, you can't LCD shop on this machine because there are only 2 lcd's that will work properly and they are now discontinued which is why they are so expensive.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,313
1条评论
Thanks for your help!!! nice meeting you guys, now I know were to ask!! jejeje
apreciated
V>
由 vikortiz 完成的
