跳转到主内容
Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
23 个问题 查看全部
Why did my water pump come on and will not stop?
The water pump on my J5 came on in the late hours of the night *by itself*. It constantly runs. Why did the pump come on 12 hours after the machine was turned off? A short?
At this time, the pump runs when i turn the power on. The display shows “warming” until the water in the tank runs out. The brew group has been maintained and the water is draining into the grounds container. Cleaning/descaling current.
So, what phantom is in my machine? What gives the pump instructions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Jura Drainageventil zerlegen, Anleitung 2
这个答案有帮助吗?
得分 2
2条评论:
Thank you! Update: I broke the gearbox to the lower part of the brew group. I know now how to reassemble it. Also, there was quite a buildup of old coffee before I refurbished it minus the broken gearbox.
So, until I find a gearbox, I will not be able to test the machine. I am still curious why the machine turned on late at night and the pump ran. I happened to be up and luckily heard the commotion. So here's a summary:
1. Machine was off for at least 12 hours. The unit powered up and the pump ran and will not stop.
2. The display reads "warming" while I refill the tank and quickly empty the tray. Never reached temp
3. The pump runs until I unplug the machine.
完成的
* I did not power up the machine in line 1.
完成的
添加一条评论
添加你的答案
Richard Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 638
