跳转到主内容
加入维修社区 - 创建账户
五十铃卡车、汽车的修理和支持指南。
Isuzu Gigga V10 engine torque settings
hey i need assistance with torque settings for an Isuzu Gigga V10 engine . the engine number is 10PEI-164725
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Tariro Ngove tell us what Giga this engine is out of. V10 Diesel?
完成的
hie, what exactly do you mean when you say what is it out of so i know what to ask my mechanic
完成的
As far as i know the vehicle is a an Isuzu truck and it needs an engine orvall done, its an Isuzu Gigga and the engine is a V10
完成的
Tariro Ngove Isuzu Giga is a model,that is where I got lost. My mistake. It was made for the Japanese market and it appears as if they were also used in Isuzu C and E model trucks
The engine you need the data for would be :
ISUZU 10PE1-S Engine
Type: 10 cylinder V type OHV direct injection
Bore x Stroke: 127x 150mm
Displacement: 19001cc
Compression Ratio: 18.0:1
Power output: 265 kw @ 2300 rpm (360hp)
Torque:1245 Nm @1400 rpm
完成的
help me for the parts catalogue of Isuzu 10PE1 engine . thanks a lot.
完成的
添加一条评论
1个答案
已选择的解决方案
Tariro Ngove  here is the document with all the engine torque settings. Isuzu 10PEI V10 Torque settings Let us know if this will work or if your mechanic needs more information. Welcome to iFixit and we’ll try and find whatever we can
这个答案有帮助吗?
得分 5
8条评论:
thnak you, if more information is needed ill get back to you. thank you once again.
完成的
hey please may you also assist me with:
1) injector pump timing degrees
2)crank shaft jornal size mains and big end specifications
3) crank oil clearance
4) filter numbers
5) clearance numbers
i hope i stated everything correctly, hoping to hear from you soon
完成的
hie, im failing to download this manual
完成的
Tariro Ngove do you get an error message when you try?
完成的
Thank you, managed to download
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Tariro Ngove 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 32
总计 2,841
