跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
wont turn on. connect to itunes logo shows.
When I try and turn the phone on the phone shows the connect to itunes logo briefly and will then turn off/screen goes blank. when i connect to itunes or the mains the phone is unresponsive or shows the connect to itunes logo.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Christian Harfield, I would start with a new battery. The iPhone does some very weird things when the battery comes to its end of life cycle. Of course you should also try to put your phone into DFU mode so you can do an iTunes firmware restore. here are some great sites that will help you with it. http://www.ismashphone.com/2008/08/recov... and http://www.iclarified.com/entry/index.ph... If it comes to changing the battery the Guide is here. It is NOT easy to do but manageable, just familiarize yourself with the steps ahead of time. The battery is available right here. Good Luck and I hope this will help you out.
这个答案有帮助吗?
得分 2
添加一条评论
ipod wont turn on disable first gen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian Harfield 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 4,421
