跳转到主内容
加入维修社区 - 创建账户
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
How do you expose the lens/sensor to blow dust off?
I can open the case but how do you get the lens/sensor exposed to blow the dust off the lens and/or sensor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You have to remove the lens assembly from the camera then open it to reach the sensor.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the reply, but how do you remove the lens assembly and open it? Is there a procedure/exploded view? from Canon?
完成的
Canon service manuals are pretty hard to find but maybe oldturkey03 could check if he can find it ?
The only tutorial I can find is how to replace a bad LCD panel on a A590:
http://www.youtube.com/watch?v=dfXG1OAgc...
完成的
添加一条评论
Se if this will help to get the lens cover off Canon PowerShot A590 IS Flash Assembly Replacement
这个答案有帮助吗?
得分 0
1条评论:
Thanks, but this procedure does not continue to lens assembly removal/opening. Is there a continuing procedure available?
完成的
添加一条评论
添加你的答案
george 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,485
