跳转到主内容
一个广泛的电子产品维修指南,从家和汽车音响到计算器。
26451 个问题 查看全部
Phone fell in water
So i droped my phone in water and its honor play there was no sound and there was headphone icon so i grabed that thing you clean your ears and cleaned headphone jack and there was red paint/liquid on it is it really bad phone works like it worked before
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@onespray let us know the exact make and model of your phone
完成的
its honor play
完成的
添加一条评论
2个答案
已选择的解决方案
@onespray the very first thing you want to do is to not try to restart the phone. This may further damage your phone. You also do not want to try to charge it any further. The next thing to do is to clean it. Completely disassemble your phone. Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for an apple iPhone 3G all the points are still pertinent to your phone. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is most likely that all of your symptoms are only related to corrosion and short circuits.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
The trouble with water damage is it can seem like your device is fine and then one day it just stops working. Even if it is working now until it is properly cleaned the corrosion will continue. It is possible that there is no internal water damage or at least minimal but the best way to be sure is to open the device (if your comfortable doing that) and inspect for corrosion/water damage. If corrosion is found your best bet would be to have it serviced for water damage at a local repair shop. Make sure they know what they are doing, all the shields need to be removed from the motherboard and it needs to be put in an ultrasonic cleaner. Any damaged components would need to be replaced which may require microsoldering.
这个答案有帮助吗?
得分 3
1条评论:
After 24hours it doesnt charge and makes some kinda beeping noise but hwn its turned off id shows charging indicator starts to beeep for like 10s turns off and agains that indicator
完成的
添加一条评论
添加你的答案
Eimantas Stregauskas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 65
