跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
I need to remove a replaced battery with no tabs
I have a reconditioned 5s that may have had a battery replaced. It doesn’t have the adhesive pull tabs so I think it was jury rigged. Any suggestions for removing a stuck battery (other than heat)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Use a syringe filled with either alcohol or acetone and squirt it under the battery to loosen the glue. Make sure it is unplugged first. No smoking allowed!
这个答案有帮助吗?
得分 2
2条评论:
A fishing line pulled under the battery would help removing it too.
完成的
The alcohol trick worked! I used a syringe to very carefully drip a little rubbing alcohol under the edges of the battery and let it sit for awhile. The plastic cover on the battery wrinkled up a bit, but with gentle lifting it came loose. The phone is now reassembled and working. Thanks for all the help!
完成的
添加一条评论
The film that comes behind screens blue or red colour i use that for everything dab it in alcohol and slide under wiggle it about loosens adhesive, I even use it to remove iPhone 7 home buttons lol
这个答案有帮助吗?
得分 2
添加一条评论
plastic credit/store card and abit of force.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Spitzer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 263
