跳转到主内容
How much needs to come out when replacing the keyboard?
I have a Mid 2009 15” MacBook Pro 2.53 GHz machine and I want to replace the keyboard. I have one at hand but there is not an instructions for it. There is only instruction for replacement of the entire upper case. How much needs to come out of the machine to get at the existing keyboard for replacement?
I’m guessing that at most, the logic board and optical drive needs to come out. I shouldn’t have to remove the display, I don’t think.
I have worked on MacBook Pro’s from 2008-9 with user detachable battery, logic board in and out, replacement of fans.
I’ve worked on Powerbook Titanium replacing the logic board, tear down and clean after juice spill when the machine as off.
I have also worked successfully on other non Mac laptops and have home build tower machines for use as web servers.
Thank you for time and attention
JK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here’s a video on how to replace the A1286 keyboard:
https://www.youtube.com/watch?v=4k0yDeOR...
这个答案有帮助吗?
得分 2
2条评论:
Thank you for this Mayer;
The sound is poor in the video. The narrator isn't speaking
well enough into the mic during the taping.
And the machine being worked on has two fans.
The one I will work on has one fan. But otherwise it
appears to be similar enough.
完成的
添加一条评论
添加你的答案
jekillen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 146
