跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad Flex 4-1470(型号名称:80SA)于 2016 年制造,配备 14 英寸触摸屏,可 360 度折叠,像平板电脑一样使用。
After a fall the computer does nothing...
My daughter knocked her laptop off the bed and it hit the floor. I know, I know…
But it happens. Right?
Now when we try to turn it on the power button lights up a few seconds but then goes off. When we attempt to charge, the LED charging light lights up as if charging, but the computer won't come on at all. The screen does nothing. The computer does nothing. Hard reset does nothing….. My husband looked inside and thinks the i/o board is possibly the problem. What would the symptoms be? Do you have any suggestions as to what the problem is and how we can fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try re-seating your memory. Also, when you are doing this, remove the memory and turn the laptop on to see if it beeps. If it does, then simply put the memory back in, after removing the power. If it does not beep, then it could very well be your motherboard. Secondly, you might try removing the hard drive( if applicable) and memory. Power the unit up to see if it responds to no memory. If it does, put just the memory back in and see it you get the “Lenovo” logo. If you do, power it down and put the hard drive back in. Try booting it again. If it does not come up with logo then your hard drive is bad and simply needs to be replaced.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stargirl Dot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 463
