跳转到主内容
加入维修社区 - 创建账户
• 输入接口:iPod™ 底座接口 / 3.5mm 立体声插孔 • 扬声器:2x Ridge TM 高/中音单元和 2x Atlas TM 低音单元 • 功放功率:2x15 瓦高/中音,2x30 瓦低音 • 频率响应:40Hz – 20kHz • 输入阻抗:>10kOhm • 电源:8x D 型电池/充电电池,电源适配器 • 尺寸(长x宽x高):500mm x 230mm x 240mm
Standard vs. Rechargeable batteries
Hello,
My Harman Kardon go play 2 takes 8 D cell batteries. Each being 1.5 volts, that makes 12 volts of power. Rechargeable batteries operate at 1.2 volts giving me 9.6 volts. I've read that some electronics are sensitive to voltage changes like this and will fry while others are not. Is it safe to use rechargeable batteries in the Go play 2?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Tyler media,
Well, I guess you can try, I think is a good investment.
For me, I do buy many rechargeable batteries, somehow for alkaline batteries, if left out for long time, the probability of leaking is high and the leaked chemical can damage terminals and seep into the circuit board, damaging it further.
You need to get a battery charger.
Some say Nitecore D4 is great, which I had one too
And perhaps AA to D cell converter / adapter
I had several batteries, ranging from Panasonic / Sanyo Eneloop and recently using Ikea Ladda battery.
I think if your side has ikea, you can consider it.
For this appliance I will recommend you to go for Eneloop pro series from Panasonic or Ikea Ladda 2450.
Link
https://www.panasonic.com/global/consume...
https://www.ikea.com/us/en/catalog/produ...
Interesting Reead
https://petapixel.com/2018/02/16/eneloop...
这个答案有帮助吗?
得分 2
添加一条评论
وواتننتن ادااا اهخخ ههههت تتتت تتت
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler media 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 1,672
