Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
这是一个好问题吗?
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
声誉积分: 11
There’s no way to do that.
评论:
This series came in two different configurations:
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
由 Dan 完成的
Thanks Dan - that answers my question
由 Jeffers De Maio 完成的
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
评论:
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
由 Dan 完成的
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 151
