跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
screen not responding when I touch it
I just replace my Itouch 2nd gen screen with a new glass and bezel. i put it all back together and the button works but it won't respond to my fingers on the screen. Could the ribbon cable have moved and it's not making a good connection?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
9个答案
最有帮助的答案
Either it isn't connected correctly or the ribbon cable may have been damaged when you put it back together, it can tear VERY easily. This would cause the touch to stop working.
这个答案有帮助吗?
得分 2
添加一条评论
Open it back up and make sure all the cables are connected.
这个答案有帮助吗?
得分 1
添加一条评论
It's also possible the logic board itself has a damaged port, but confirm that it's not the digitizer screen itself.
这个答案有帮助吗?
得分 1
添加一条评论
Make sure that the Digitizer ribbon is clicked in all the way, that was the problem for me.
这个答案有帮助吗?
得分 0
添加一条评论
If the ribbon cable is plugged in good, make sure you reboot. It is about like the screens, the ipod has to reboot to see that it is connected.
这个答案有帮助吗?
得分 0
1条评论:
Just thought of something else, the thick ribbon cable that runs up to the wifi/touch connection board could be damaged also. Changing it is very hard and this is just to reference another place to look.
由完成的
添加一条评论
try restoring the iPod touch.
这个答案有帮助吗?
得分 0
添加一条评论
maybe the touch screen has been damaged during yout operation or there is a loose connection
这个答案有帮助吗?
得分 0
添加一条评论
how did you know that this was the problem with the touch screen? the "black resistor" I am having the same trouble with my touch screen. I have restored, rebooted, bought 3 different model screens, tried gorilla tape to hold down a tight connection, used 90% alcohol to clean the insides everything. Everything is working find on the ipod except I can't get the touch screen to work and it's driving me nuts!
这个答案有帮助吗?
得分 0
添加一条评论
i figured out why the touch screen isn't working or responding, this is cause by static tiny rectangle black resistor is blown out, located on the upper pcb right between the square metal and
square plastic(like diamond)
and it is impossible to fix it ,
这个答案有帮助吗?
得分 -2
添加一条评论
添加你的答案
Al Urban 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 43,431
