跳转到主内容
加入维修社区 - 创建账户
Shark Rocket HV301 是 Shark Rocket 300 系列吸尘器的第二款产品。它是一款二合一吸尘器,配有多种附件,能够清洁不同表面。其时尚轻便的设计使它可以轻松在任何家庭环境中操作。
will nt pick up
dirt goes into the stick and gets cloged up have to take the stick and clean it and dose pick up. when i first got it i loved it. but right now it is worthless.just bought a navagater and is very hard to push.no more sharks for me.can you please tell me where i can get the rocket fixed. thank you. i live in rogersville tn.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You may have a partial clog somewhere along the way that is keeping you from getting full suction. Try this - without the power head or rod attached turn on the vacuum, now place the palm of your hand where the rod would normally attached. Does it pull your hand towards it? If so, repeat the process by attaching the rod only. If there wasn’t good suction before attaching the rod, you likely have a clogged filter or collection chamber; try cleaning the filters with some warm water and fully empty the collection chamber. If the suction was good there, but bad after connecting the rod, then you have a clog somewhere in the rod. You might be able to fish it out or break it loose with a straightened coat hanger. If suction was good at both of those places then take a look at the hose that is at the bending point of the power head, here is where that hose will crack (this was the case for mine). A crack in the hose will lead to poor suction. Best of luck fixing the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
barbara bond 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 344
