跳转到主内容
加入维修社区 - 创建账户
Acer Aspire ES1-332 的维修指南和故障排除信息。这款经济型笔记本电脑采用 Intel Apollo Lake 平台,配有 13.3 英寸屏幕。
acer logo loop and reset error
my laptop was stuck on a boot loop on the acer logo ive looked online and everyome mostly said to reset it but when i try to reset it it says error and ive tried to do the biomes boot thing aswell but i cant find it in the biomes.Idrk what to do someone please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Booting into BIOS can fix the problem because it allows you to boot from a Windows ISO image instead of the hard drive. You can then use the ISO image to perform a clean install.
What’s puzzling is that you said that your computer is stuck in a boot loop, and you tried to reset it but got an error message. But if it’s stuck in a boot loop, then it is impossible to reach the screen needed to reset it.
Is the issue that your computer is stuck in a loop of continuous restarts, or is the issue that your computer won’t let you reset it?
这个答案有帮助吗?
得分 1
2条评论:
it keeps on showing acer over and iver again but when i try to reset it doesnt work
由完成的
In that case, please try the following:
1. Turn your computer on and start hitting the F11 button very rapidly over and over again.
2. If an "Advanced Options" screen appears, select the Startup Repair option. This will tell Windows to repair what is blocking Windows from loading onto your screen.
由完成的
添加一条评论
添加你的答案
Fahim Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 2,291
