跳转到主内容
Guides and repair information for televisions made by ProScan.
20 个问题 查看全部
I have a Cracked tv LED Screen
I was playing my Xbox when the battery from the controller came loose and the corner of it, hit the screen of my Proscan plded-3274 Uk bi. There are horizontal lines Vertical lines. Where would I acquire a replacement LED screen? The TV is three years old so not under any warranty etc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@samdamji it will be difficult to find a proper panel and it will most likely cost you more than a new TV would. Remove the back from your TV and take a look at the label on the panel. Use the model number on that to search for a replacement. The only other way would be to find a TV with the same panel as yours but that is otherwise broken. Then harvest the panel from that one. To replace the actual panel is not as bad as trying to find a replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 159
