跳转到主内容
Guides and support for devices that play video from Blu-Ray Discs.
111 个问题 查看全部
My Sanyo blueRay player
My SANYO BlueRay player has stopped playing any of my BlueRay disc’s. However, IT WILL PLAY regular DVD’s. Since it plays regular disc’s , I’ll rule out a motor problem. All of my disc’s are totally free of scratches and dust free. I contacted Sanyo but they were of no help. When I insert a Blueray disc, and I click on the symbol for disc, it flashes once but then does absolutely nothing. I don’t know the 1st thing about DVD players but I’m thinking that the lens for BlueRay is dirty. What is the best way to clean it ? Any other suggestions would also be appreciated.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
My first suggestion would be to blow into the slot. Bigger dust parts will be blown from lenses.
Be careful to use dry air and not spit into the slot.
Many years ago this worked often with CD/DVD Drives.
这个答案有帮助吗?
得分 0
1条评论:
I tried your suggestion, but it did not work. thanks anyway
完成的
添加一条评论
@ramses2 use one of the commercially available lens cleaner discs and run it through the process a few times. If that does not work you will have to take your Blu-Ray player apart to try to clean the lens manually. I usually wipe off the lenses with 95% (or greater) isopropyl alcohol or a cotton swab if the drive can expose the lense. This will of course only work if it is caused by a dirty lens, not a failed reader etc.
Let us know the exact model of your BR player
这个答案有帮助吗?
得分 0
3条评论:
Hello "Old Turkey03,
I opened the main case and I see a circuit board and a case that the disc goes into. That case is connected to the circuit board by 3 wire harnesses. Now, examining the "disc case" , which I have been able to lift out, I do not see anything that remotely looks like a lens. Am I supposed to find 2 glass lenses ?
Sanyo Model # 11LE E234498
PS: on the rear of the main exterior case it says "Class 1 laser product.
Thank you for any help you have. :)
Ramses2
完成的
@ramses2 I cannot find anything with that number. There does not seem to be a model from Sanyo with those numbers. check some more for a model number possibly starting with FWDV etc.
完成的
Sorry Guy, I mistakenly gave you the wrong number. I had to get a magnifiying glass to find it. # FWBP706F (can't tell if that is a zero or an O)
完成的
添加一条评论
添加你的答案
Richard Whiting 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,824
