跳转到主内容
加入维修社区 - 创建账户
小米 Redmi Note 系列旗下的一款智能手机。
Redmi note 4 charging issue :
1.It is not continuously charging …….after 5 min or in few min it will automatically charging stopped….after i re plugged its charging ..and again same issue.
one day its charging up to 3%. fullday it connected battery indication is glowing but at the end same 3%
what is the issue any suggestion vradhakrishnan25@gmail.com
please help me
i tried many things:
1. I replaced new battery….
2. mobile factory reset by “mi pc suite mode”
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Try to resolder the USB port pins.
If you have a multimeter it is more easy to locate the problem. If you have one let me know and i will tell you where to start.
这个答案有帮助吗?
得分 8
7条评论:
Thank you bro .....the mobile power port pin is sometime shacking......i think it is broken..
thanks for the suggestion....
由完成的
i'm glad it helped you
由完成的
yes bro the issue is fixed as your suggestion .....i given to service center again ..they replaced the mobile power port pin now its working fine .......thank u bro........
由完成的
Redmi 4 charging problem solve https://androidji.com/redmi-note-4-charg...
由完成的
Thanks for the blog! here you will also find many useful blogs https://www.bpwltd.com/hangover-tamil-du...
由完成的
显示更多的2条评论
添加一条评论
添加你的答案
Radhakrishnan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 37
总计 10,958
