跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Lawn mower won't move forward or backward
I was mowing the yard and my lawnmower just stopped. It was still running and blades were still ingaged but would not go forward or backward.
It is a Yardman.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Mine did he same. After examining the belts and everything being okay, I saw a lever was pushed into neutral! Easy fix
完成的
添加一条评论
2个答案
已选择的解决方案
@tabe918 what model Yardman is it and what have you tried. If it is a riding mower it could be as simple as a failed drive belt
这个答案有帮助吗?
得分 0
添加一条评论
If its hydrostatic, check to see if it has a disconnect lever, which allows you to push it around by hand.
If it is a gear drive start engine and leave shifter in neutral,move speed control lever to top speed and bring lever back to first speed them put in gear to see if it moves,sometimes when you stop in any gear above 2nd or 3rd it will set the vari-speed pulleys at that speed,so you need to go to a higher speed to get the pulley to engage,stopping at 1st speed is best so you won't have this problem,under hood is a decal usually will tell you what’s going on. Also your brake may be stuck. It is located on the center of the rear axle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tabatha EVANS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 8,824
