跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
How to get iPhone to turn back on?
I left my iphone and put it to sleep, and then half an hour later, I went to turn it back on again and it didn’t respond. During that time, the phone was in my pocket doing absolutely nothing. I have tried all of the solutions that I found online including the force restart, etc. I have tried plugging it into my computer to see if it recognizes it, and it doesn’t. I have tried charging it and it still does not do anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Replace battery first and check that you can find the clue what you have to do.
这个答案有帮助吗?
得分 0
添加一条评论
As Akash suggested, if you can remove the battery it will help. I would lift the screen and disconnect the battery, then plug the phone into a computer with iTunes installed. If the phone boots up with the battery disconnected, then the battery is likely the problem: follow this guide to replace it. If it doesn’t boot up, you should hopefully still get an error message of some description from iTunes. The error message should give you a better indication of what is wrong.
这个答案有帮助吗?
得分 0
2条评论:
An iPhone will not boot without a battery...
完成的
@refectio problem here is one cannot upvote the comment :P
完成的
添加一条评论
添加你的答案
Aryan Mistry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 80
