跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
LCD doesn’t work
Hi guys!
Display doesn’t work in my iMac 2017. I already replaced LVSD cable. It didn’t help. Can it be cause of the problem?(see picture)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Technically the cable is called an iDP or eDP cable as it handles a different signaling system (retina or better) than the older LVDS cable.
完成的
ruslansolovka what's the 820-xxxx on your board? If it is anything like a 820-00431 or a 820-00597 then there are no schematics available yet. Apple is getting smart and more devious in hiding those.
完成的
I can’t find that number on the board. Maybe it’s on other side
完成的
添加一条评论
2个答案
最有帮助的答案
Yes! it does look like some moisture damage and the components have fallen off. I don’t have a schematic and boardview for this system so I can’t tell you what you’ll need to get to replace the damaged components.
Update (04/14/2019)
Are you able to get an external monitor to work?
这个答案有帮助吗?
得分 2
9条评论:
It looks indeed like a liquid damage..but all the way up there on an iMac ? Singing in the rain with my iMac beside ? ;)
完成的
@arbaman - Yes it's an odd place! Rain coming in from the back vent? Could have been near an open widow getting blown in.
完成的
No, it’s not placed near window. There was never any liquid on it. Damaged only 3 parts. I guess it burned for some reason.
完成的
@oldturkey03 - Any ideas on the missing components
完成的
Have no idea:)
完成的
显示更多的4条评论
添加一条评论
Hi @ruslansolovka
did you figure out what the problem of your iMac was? In fact no components seem to be missing on your board (at least not within the provided image section). Just for comparison I added a picture of my (fully working) A1418 2017 4k iMac of the exact same location.
Pleas note, that not all of the ‘stain’ is due to water damage - but I would recommend taking a closer look at the tiny capacitors of the upper circle as well as the same section on the other side of the board
Best
这个答案有帮助吗?
得分 1
1条评论:
Time is a great healer! I'm sure ruslansolovka's system is working at this point (note the date, a little over 2 years ago)
完成的
添加一条评论
添加你的答案
ruslansolovka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 482
