跳转到主内容
加入维修社区 - 创建账户
XV-21 是一款由 Neato Robotics 生产的扫地机器人,专为清洁宠物毛发和皮屑而设计。
LCD Display Not Working
My XV-21 display lights up but there is no display. I know you can replace it but does anyone now how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
My lcd menu is empty. Light is flashing amber
由完成的 分享
添加一条评论
1个答案
Unfortunately I have had this same problem twice on my Neato XV (two years apart). Both times the problem was a broken LCD display card, replacing the card fixed the problem. I was able to buy a used Neato XV LCD display card on eBay for about $40. Amazon may have them too.
Follow the Neato XV-21 repair guide on ‘Motherboard Repair’ (thank you Nastassja Klipsch!!) Until you get the two halves of the robot apart. There are a ton of screws, so if I have to do this again I will take better care to write down where they all came from (I started to forget).
You don’t need to remove the Lidar unit, so stop at that point in the guide. The LCD display card is screwed into the top shell of the robot. Once you get the robot apart it is pretty easy to disconnect the cable connector and replace the display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doug Schommer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 28
总计 2,606
