跳转到主内容
加入维修社区 - 创建账户
NeatDesk 于 2006 年首次发布,是一款带有自动文档馈送 (ADF) 和双面扫描功能的台式文档扫描仪。早期版本的型号为“ADF-070108”,较新版本的型号为“ND-1000”。
Scanner just went out
My neat scanner just went dead. Unplugged and plugged it in again; even plugged it into another outlet. Is there a reset button? Can it be fixed or is it not worth it? We had a power outage and when the power came back on it wouldn’t work. Could a power surge have burned out the power source in the scanner?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
If possible, it is always worthwhile to at least attempt to repair anything.
Not only is there the satisfaction of having done so, if successful, it means that in this case for a while at least it won’t add to the ever growing mountains of e-waste.
The resultant power surge that may have occurred when the power was reconnected after the outage could have burnt out components in the scanner,
Here’s a link to the ifixit NeatDesk™ 台式扫描仪电路板维修 guide. This should be of some help in opening the scanner to initially do a visual inspection to see if there is any obvious electrical damage to the electronic components, such as burnt out surge suppressors, blown capacitors and blown fuses etc.
If you do see something (or even if you don’t) and are unsure, take some close up pictures of the circuit board and post them back here.
Here’s how to do this.
在已经存在的问题里加入图片
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
NeatDesk™ Desktop Scanner图片
指南
难度:
中等
1 hour
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Eileen Halverson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 564
