跳转到主内容
加入维修社区 - 创建账户
华为2016年旗舰智能手机。拥有一体成型机身以及徕卡设计的双后置摄像头。拥有32/64 GB存储空间以及6种不同配色。包括型号有 EVA-L29, EVA-L19, 以及 EVA-L09.
Replacement display assembly not working after assembly
So i bought a display assembly for a Huawei P9 and for some reason it doesnt work after i moved all parts (cameras, mainboard, etc.)from one assembly to the other.
The weird thing is that it works totally fine when plug in the display flex cable before i assemble anything.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You probably bet a ribbon cable, so look out not to bend them.
这个答案有帮助吗?
得分 0
添加一条评论
I don’t have a lot of familiarity with this model but check to make sure you aren’t putting pressure on any of the connectors or cables. Pinched cables can cause problems sometimes. Also, there might be something pressing on the screen causing it not to work. A bent frame can sometimes be the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Antonio Cappuzzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 257
