跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
What is the solvent that removes battery
Can you please tell me what is the solvent that loosens the battery is so I can attempt removal before buying a new battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
iFixit uses acetone. I use methanol.
这个答案有帮助吗?
得分 3
添加一条评论
Hi @secretuser
This a good guide you can follow :)
How to Use iFixit Adhesive Remover
Is the iFixit adhesive remover just isopropyl alcohol?
Cheers
这个答案有帮助吗?
得分 2
添加一条评论
The methanol (denatured alcohol) is safer for you and the plastics in computers. It worked fine for me. A bit stubborn and the battery packages get a bit twisted, but they didn't rupture. I used plastic spudgers to pry up gradually. Work from the top edge nearest the bottom of the computer. Spraying in the alcohol with a small plant sprayer. Tilt to allow the alcohol to reach the adhesive strips.
The acetone might be faster and easier, but even with ventilation there are the fumes.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
JMG 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 30
总计 1,802
